Use the Resource Shifts dialog box to define shift calendars for resources.
Display options bar: Displays global shifts.
Shift Name: Lists shift calendar names.
Add: Click to add the name of a new shift calendar.
Delete: Delete the selected shift calendar.
Modify: Click to view or modify the work schedule for the selected shift calendar.
