Use the Select Activity dialog box to associate an activity with an issue or an expense.
Display Options bar: Lists options for changing the activities display. You can change the columns, filtering, grouping and sorting, font, and colors.
Search: Type an Activity ID or name to display a filtered list of activities that begin with this value.
Select Activity table: Lists the ID, name, and status of activities in the open project. To sort the display, click a column label.
Select: Associates the selected activity with the issue or expense.
Clear: Removes an activity assignment from an issue or expense.
