Use the dialog Select Calendar To Copy From box to copy the settings from the selected global, project, or shared resource calendar when creating a new calendar. You can then customize this calendar to meet specific needs.
Display Options bar: Click to change the calendars display.
Calendar Name: Lists calendar names for the current calendar type. To sort the display, click the Calendar Name column label.
Default: If your current display is Global Calendars, indicates the default global calendar. To sort the display, click the Default column label.
Select: Copies the selected calendar.
