Use the Select WBS dialog box to assign a work breakdown structure (WBS) element to an activity, threshold or issue. Also use the Select WBS dialog box to specify the WBS element to which you want to add a project's WBS.
Display Options bar: Lists options for changing the WBS display.
Search: Type a WBS code or name to display a filtered list of items that begin with the letters you enter.
WBS Code: Lists each WBS element in the open project.
WBS Name: Lists the name of each WBS element in the open project.
Responsible Manager: Lists the responsible manager for each WBS element in the open project.
Select: Applies your selection and closes this dialog box.
