Use the Select WBS to add into dialog to select the WBS node to which you want to add the new project.
Display Options bar: Click to change the WBS table display.
WBStable: Lists the ID, name, and additional information about existing WBS elements. To sort the display, click a column label.
Select: Adds the new project to the selected WBS element.
