Use the Top Layout toolbar to customize the top layout of the active window. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon | Function | Displays by default? | Enabled when active window is: | Corresponding menu command |
Shows or hides the table view in the top layout. | Yes | Activities, Projects, Resources, WBS | View > Show on Top > Table | |
Shows or hides the Gantt chart in the top layout. | Yes | Activities, Projects, WBS | View > Show on Top > Gantt Chart | |
Shows or hides the Activity Network in the top layout. To set Activity Network options, open an Activity Network layout, or save the Activity Network layout, click the icon, then choose the appropriate option. | Yes | Activities | View > Show on Top > Activity Network | |
Shows or hides relationship lines in the Gantt Chart. | Yes | Activities | None | |
Shows or hides a chart view. | Yes | Projects, Resources, WBS | View > Show on Top > Chart View | |
Shows or hides the Activity Usage Spreadsheet in the top layout. | No | Activities | View > Show on Top > Activity Usage Spreadsheet | |
Shows or hides columns in the Project/Gantt Profile. | No | Tracking | None | |
Shows or hides the top window in the Project/Gantt Profile. | No | Tracking | None | |
Shows or hides the Resource Usage Spreadsheet in the top layout. | No | Resource Assignments | View > Show on Top > Resource Usage Spreadsheet | |
Arranges children horizontally or vertically in chart views. Click the icon to select an option. | No | Projects, Resources, WBS | View > Arrange Children | |
Aligns children in chart views. Click the icon to select an option. | No | Projects, Resources, WBS | View > Align Children | |
Enables you to apply an existing chart box template to the current layout, or customize your own. Click the icon to select an option. | No | Projects, Resources, WBS | View > Chart Box Template |
Tips
- To show icons on the toolbar that do not display by default, you must customize the toolbar.
- The icons on this toolbar do not have corresponding shortcut keys.
