Add a project to the EPS hierarchy
Once you set up the EPS structure, you can add an unlimited number of projects as follows:
  1. Choose Enterprise, Projects, then select the EPS node or root element to which you want to add a project.
  2. Click on the Edit Toolbar or choose Edit, Add.
  3. Follow the instructions in the Create a New Project Wizard.
    To quickly add a new project using the default settings, click Finish on the Create a New Project Wizard.
  4. Use the detail tabs across the bottom of the Project window to add details specific to this project.
Related Topics
Set up the EPS structure
EPS node
Root Element
Edit Toolbar
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
