Add an OBS element
  1. Choose Enterprise, OBS.
    A root OBS element is automatically assigned to the root EPS node so that a default OBS element can be assigned to each project you add to the EPS root.
  2. Click the OBS Name column label to display the OBS hierarchy.
    The outline symbol in the OBS Name column label indicates a hierarchy display.
  3. Select the OBS element immediately above and at the same hierarchy level as the element you want to add, then click Add.
  4. Click the General tab, type the OBS Name, then click Modify to type a description of the OBS element in an HTML editor.
    In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
  5. Click the Users tab to view the users and corresponding security profiles associated with an OBS element. You can also assign users from this tab, if you have appropriate access rights.
  6. Click the Responsibility tab to quickly see where responsible managers (OBS elements) are assigned across the enterprise. Select the OBS name for whom you want to see assignments.
Tip
Related Topics
Root Element
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
