Add Projects dialog box
Use the Add Projects dialog box to specify the projects to include in the selected portfolio.
Display Options bar: Click to change the table display.
Add Projects table: Lists your organization's project hierarchy. To sort the display, click a column label.
Assign: Assigns the selected projects to the portfolio.
Remove: Removes the selected projects from the portfolio.
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
