Adding activities using a wizard
Activities are the fundamental work elements of a project. They are the lowest level of a work breakdown structure ( WBS) and, as such, are the smallest subdivision of a project that directly concerns the project manager.
If the Use New Activity Wizard checkbox is marked in the User Preferences dialog box, the New Activity wizard displays each time you add an activity to guide you through the process.
Related Topics
Set wizard options
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
