Assign Reports dialog box
Use the Assign Reports dialog box to add reports to and remove reports from the selected report batch.
Display Options bar: Click to filter, group, and sort the report batch display.
Report Name: Lists names of existing reports. To sort the display, click the Report Name column label.
Assign: Adds the selected report to the report batch.
Remove: Removes the selected report from the report batch.
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
