WBS Code: Lists codes for work breakdown structure (WBS) elements to which the selected work product or document is assigned. To remove a work product or document assignment, select the assignment you want to remove, then click Remove. To sort the display, click the WBS Code column label.
Activity ID: Lists IDs for activities to which the selected work product or document is assigned. To sort the display, click the Activity ID column label.
Activity Name: Lists the names of activities to which the selected work product or document is assigned. To sort the display, click the Activity Name column label.
Assign: Assigns the selected work product or document to a WBS element or activity.
Remove: Removes the selected work product or document assignment.
