Create a custom toolbar
Rather than customizing existing toolbars, you can create custom toolbars that include only the icons you want to display in groups meaningful to you. For example, you could create one toolbar that includes only the icons you need for your work, then hide all other toolbars.
To create a custom toolbar:
  1. Choose View, Toolbars, Customize.
  2. On the Toolbars tab, click New.
  3. In the New Toolbar dialog box, specify a name for the toolbar, then click OK.
    When you click OK, a new toolbar is added docked at the top of the window, below all other toolbars in the toolbar area on its own row.
  4. In the Customize dialog box, click the Commands tab.
  5. In the Categories list, select a category to view the available commands for that category.
  6. Select the command you want to move to the custom toolbar, then drag it to the new custom toolbar row or column that was created when you added the toolbar.
    Repeat this step for each command you want to add to the toolbar.
Tips
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
