Create resource codes
  1. Choose Enterprise, Resource Codes.
  2. Click Modify.
  3. Click Add, then type the name of the resource code.
  4. In the Max Length field, specify the maximum number of characters for the resource code's values.
  5. Click Close.
Note
Tip
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
