Customize Resource Usage Spreadsheet columns
You can customize the columns that display in the left and middle panes of the Resource Usage Spreadsheet layout in the Activities window.
  1. In the left pane, click the Display Options bar, then choose Columns, Customize. In the middle pane, click the Display Options bar and choose Columns, Customize.
    You can select different columns to appear in each pane.
  2. To add a column to the spreadsheet, select it in the Available Options section, then click .
  3. To add all available columns to the spreadsheet, click .
  4. To remove a column from the spreadsheet, select it in the Selected Options section, then click .
  5. To remove all current columns from the spreadsheet, click .
    You must select at least one column to appear in the spreadsheet.
  6. To change the order in which columns appear, in the Selected Options section, select a column you want to move:
    To move the column left, click  .
    To move the column right, click  .
  7. To update columns in the spreadsheet, click OK, or to view your changes without closing this dialog box, click Apply.
    To restore the default columns, click Default.
Note
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
