Cut and paste a resource
  1. Choose Enterprise, Resources.
  2. If necessary, choose View, Filter By, All Resources, to display all resources.
  3. Choose View, Group and Sort By, Default, to display the resource hierarchy.
    If resource security is enabled you can only view resources you have access to. Therefore, you can cut and paste a resource only to the hierarchy you have access to.
  4. Select the resource you want to cut and paste, then choose Edit, Cut.
  5. Select the resource to which you want to add the cut resource, then choose Edit, Paste.
Notes
Related Topics
Copy and paste a resource
Introduction to Resource Security
Root Node
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
