Default filter criteria
The following table lists the criteria used for the predefined activity filters.
Filter Name
Display all rows
Parameter
Is
Value
Completed
Where
Activity Status
Equals
Completed
Critical
Where
Critical
Equals
Yes
Has Finish Constraint
Where
Or
Or
Or
Or
Or
Or
Or
Primary Constraint
Primary Constraint
Primary Constraint
Primary Constraint
Secondary Constraint
Equals
Equals
Equals
Equals
Equals
Equals
Equals
Equals
Finish On
Finish On or Before
Finish On or After
Mandatory Finish
Finish On
Finish On or Before
Finish On or After
Mandatory Finish
Has Start Constraint
Where
Or
Or
Or
Or
Or
Or
Or
Primary Constraint
Primary Constraint
Primary Constraint
Primary Constraint
Equals
Equals
Equals
Equals
Equals
Equals
Equals
Equals
Start On
Start On or Before
Start On or After
Mandatory Start
Start On
Start On or Before
Start On or After
Mandatory Start
In Progress
Where
Activity Status
Equals
In Progress
Level of Effort
Where
Activity Type
Equals
Level of Effort
Longest Path
Where
Longest Path
Equals
Yes
Milestone
Where
Or
Activity Type
Activity Type
Equals
Equals
Start Milestone
Finish Milestone
Negative Float
Where
Total Float
Is less than
0.0d
This criterion only appears when P6 Professional is connected to a P6 Professional database.
New Feedback to Review
Where
New Feedback
Equals
Yes
Non What-If
Where
Project Status
Is not equal to
What If
Non Critical
Where
Critical
Is not equal to
Yes
Normal
Where
Or
Activity Type
Activity Type
Equals
Equals
Task Dependent
Resource Dependent
Not Started
Where
Activity Status
Equals
Not Started
Related Topics
Create a filter
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
