Display Toolbar
Use the Display toolbar to zoom in and out of the current display, expand or collapse data elements, show or hide Hint Help, and add attachments. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon
Function
Displays by default?
Enabled when active window is:
Shortcut keys
Corresponding menu command
Zooms in on a timescaled layout (Gantt Chart, spreadsheet, or profile). Zooming in displays a shorter range of time using smaller time intervals, for example, zooming from a quarterly to monthly to weekly display.
Yes
Activities, Projects, Resource Assignments, Tracking, WBS
None
View > Zoom > Zoom In
Zooms out of a timescaled layout (Gantt Chart, spreadsheet, or profile). Zooming out displays a longer range of time using larger time intervals, for example, zooming from a weekly to monthly to quarterly display.
Yes
None
View > Zoom > Zoom Out
Re-sizes chart views to fit the entire chart into the visible area.
This icon is enabled when you display a chart view in the active window.
Yes
Activities, Projects, Resources, WBS
None
View > Zoom > Zoom to Best Fit
Resets all toolbars, default icons, and toolbar locations back to factory defaults.
No
All
None
View > Reset All Toolbars
Locks toolbars in their current positions.
No
All
None
View > Lock All Toolbars
Enables you to create a new tab group at the bottom of the screen.
Yes
All
None
View > Tab Groups > New Horizontal Tab Group
Enables you to remove all tab groupings and display all open tabs in one tab group.
Yes
All
None
View > Tab Groups > New Vertical Tab Group
Enables you to create a new tab group at the side of the screen.
Yes
All
None
View > Tab Groups > Merge all Tab Groups
Enables or disables Hint Help.
Yes
All
None
View > Hint Help
Expands all collapsed elements in a grouped or hierarchical table view.
No
All
Ctrl+Add
View > Expand All
Collapses all expanded elements in a grouped or hierarchical table view.
No
All
Ctrl+Subtract
View > Collapse All
Opens the Collapse To dialog box. Use the Collapse To dialog box to select the grouping band you want to collapse or expand to in the current layout. The selection available in the list is based on the grouping bands displayed in the current layout.
No
None
View > Collapse To
Enables you to add curtain and text attachments, and to show or hide all curtain attachments. Curtain attachments highlight a specific time period in a Gantt Chart, while text attachments display custom text you enter in a Gantt Chart.
To add a curtain attachment to a Gantt Chart, click the icon, point to Curtain, then choose Add to open the Curtain Attachment dialog box.
To show or hide all curtain attachments, click the icon, point to Curtain, then choose the appropriate option.
To add a text attachment to a Gantt Chart, click the icon, then choose Text to open the Text Attachment dialog box. Use the Text Attachment dialog box to create formatted text and insert it in a Gantt Chart.
This icon is enabled when you display a Gantt Chart in the Activities window.
No
Activities
None
View > Attachments
Opens the local P6 Professional Help. The topic that displays when you open the Help reflects the currently active window.
If the Always launch Online Help for the F1 shortcut key and context-sensitive help setting is not selected in the P6 Professional Online Help URL section of the Admin Preferences dialog box, the local help will launch when clicking the Help icon or button in the open dialog box.
This icon is enabled when no dialog box is open. To access the Help topic for a dialog box, click the Help icon or button in the open dialog box.
Yes
All
Ctrl+F1
Help > Local Help
Opens the Online P6 Professional Help. The topic that displays when you open the Online Help reflects the currently active window.
If the Always launch Online Help for the F1 shortcut key and context-sensitive help setting is selected in the P6 Professional Online Help URL section of the Admin Preferences dialog box, click the Help icon or button in the open dialog box to access the online help topic for a dialog box.
Yes
All
Ctrl+Alt+F1
Help > Online Help
Tip
Related Topics
Customizing toolbars
Zoom in and out of a timescaled layout
Tile windows horizontally or vertically
Using Hint Help
Add a curtain attachment in a Gantt Chart
Add a text attachment to a Gantt Chart
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
