Filter a tracking layout
For layouts that include data displayed in column or table format, you can add one or more filters to further customize the type of information you want display.
  1. Choose View, Filter By, Customize.
    In the Top Layout window, you can also click the Display Options bar (in the right pane), then choose Top Layout Options, Filters, or right-click in the table and choose Filters.
  2. In the Parameter column, double-click the first row and select Any of the Following or All of the Following.
  3. In the Parameter column, double-click the first blank row, then select a field by which to filter.
  4. In the Is column, double-click the corresponding field and select the filter’s search condition or comparison operator.
  5. In the Value column, double-click the corresponding field and type or select the value you want to display for the specified field.
  6. To add another filter field, click Add, then repeat steps 2 through 6 for each field you want to include in the filter.
Tips
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
