General tab - Organizational Breakdown Structure dialog box
OBS Name: The selected OBS element's name. You can type a new name.
OBS Description: A description of the selected OBS element. You can only view the description in this field; to add or edit a description, you must use the HTML editor.
Modify: Click to add or edit the description for the selected OBS element in an HTML editor. In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
Print: Click to print the displayed description.
Copy: Click to copy the selected text. After copying text, you can paste it into the HTML editor or into another application.
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
