General tab - Roles dialog box
Role ID: The selected role's ID. You can type a new ID.
Role Name: The selected role's name. You can type a new name.
Responsibilities: The selected role's responsibilities. You can only view the description in this field; to add or edit a description, you must use the HTML editor.
Modify: Click to add or edit the description for the selected role in an HTML editor. In the editor, you can format text, insert pictures and tables, copy and paste information from other document files (while retaining formatting), and add hyperlinks.
Copy: Click to copy the selected text. After copying text, you can paste it into the HTML editor or into another application.
Print: Click to print the displayed description.
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
