Group and sort resource assignments
  1. Choose Project, Resource Assignments, then choose View, Group and Sort By, Customize or click the Display Options bar and choose Group and Sort By.
  2. Choose one of the predefined group and sort options, or, to customize grouping and sorting, choose Customize.
If you choose Customize
  1. In the Group By column, double-click the cell, then select the field by which you want to group.
  2. Click Sort, then select a sort order for the grouping. Click OK.
  3. To change a group's display color and font, double-click the appropriate Font & Color field.
  4. To group and sort by additional fields, repeat steps 1 and 2.
Tips
Related Topics
Create a future period bucket planning layout
Future period bucket planning
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
