Import Layout As dialog box
Use this dialog box to select where the layout should be imported.
Layout Name: The name of the layout. You can type a new name.
Available to: The category of users who can access the new layout. You can select a different user category.
User: The user to which you want to assign the layout. Click to select a user.
Project: The Project with which you want to associate the layout.  Depending on the user privileges, is enabled to permit selecting a project with which to save the layout.
Save: Saves the current layout according to the options you specify.
Cancel: Closes this dialog box without saving the current layout.
Notes:
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
