Introducing P6 Professional
When P6 Professional is connected to a P6 EPPM database:
P6 Professional is a separate component of P6 EPPM that integrates traditional project management with streamlined resource and cost management.
It provides a set of robust features aimed primarily to address the needs of project planners and schedulers. (P6 Professional connected to a P6 EPPM database is not used to perform administrative or most enterprise-level tasks.)
P6 Professional features include the following:
When P6 Professional is connected to a P6 Professional database:
P6 Professional is a comprehensive, multiproject planning and control software, built on Oracle and Microsoft SQL Server relational databases for enterprise-wide project management scalability. P6 Professional can stand alone for project and resource management, and it enables your organization to store and manage its projects in a central location. The module supports work breakdown structures (WBS), organizational breakdown structures (OBS), user-defined fields and codes, critical-path-method (CPM) scheduling, and resource leveling.
P6 Professional enables you to budget, prioritize, plan, administer, and manage multiple projects; optimize limited, shared resources; control changes; and consistently move projects to on-time and on-budget completion. It provides customizable interfaces, scalable and flexible tools, and easy integration with project management software outside of the P6 suite, including Oracle Contractor, Microsoft Project, and Microsoft Excel.
P6 Professional provides
Related Topics
Oracle Contractor
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
