Layout Toolbar
Use the Layout toolbar to customize the layout of the active window and to access user preferences. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon
Function
Displays by default?
Enabled when active window is:
Corresponding menu command
Opens the New Layout dialog box. Use the New Layout dialog box to create a custom tracking layout.
No
Tracking
View > Layout > New
Opens the Open Layout dialog box. Use the Open Layout dialog box to select and display a different layout, and to import and export layouts.
No
Activities, Projects, Resource Assignments, WBS, Tracking
View > Layout > Open
Saves the currently displayed layout.
No
Activities, Projects, Resource Assignments, Work Breakdown Structure, Tracking
View > Layout > Save
Saves the currently displayed layout as a new layout.
No
View > Layout > Save As
Opens the Bars dialog box. Use the Bars dialog box to specify the style and labels for the bars in a Gantt Chart.
This icon is enabled when you display a Gantt Chart in the active window.
Yes
Activities, Projects, Tracking, Work Breakdown Structure
View > Bars
Enables you to select a predefined column layout or to customize the columns that display in the active window. The available options vary for each window. To customize columns, click the icon, then choose Customize.
This icon is enabled when you display a table view in the active window.
Yes
All except Reports
View > Columns
Opens the Timescale dialog box. Use the Timescale dialog box to specify the timescale you want to display in the current Gantt Chart, profile, or spreadsheet layout.
Yes
Activities, Projects, Resource Assignments, Tracking, Work Breakdown Structure
View > Timescale
Enables you to select a predefined filter or to create a custom filter. The available options vary for each window. To create a custom filter, click the icon, then choose Customize.
Yes
All except Work Breakdown Structure and Project Expenses
View > Filter By
Enables you to select a predefined grouping and sorting option, or to specify your own grouping and sorting criteria. The available options vary for each window. To customize grouping and sorting, click the icon, then choose Customize.
Yes
All
View > Group and Sort By
Numbers each row in the Activities view.
This icon is enabled when you display an Activity table, Gantt Chart, or Activity Usage Spreadsheet in the active window.
Yes
Activities
View > Line Numbers
Opens the Table, Font and Row dialog box. Use the Table Font and Row dialog box to change the appearance of text, color, and the height of rows in your display. The available options vary for each window.
Yes
All
View > Table Font and Row
Opens the User Preferences dialog box. Use the User Preferences dialog box to specify your settings and preferences, including how to display time, date, and currency information. You can also set options to send email, specify startup options, and change your password.
Yes
All
Edit > User Preferences
Tips
Related Topics
Customizing toolbars
Tracking layouts
Open a layout
Open a tracking layout
Save a layout in the Activities or Resource Assignments window
Save a layout in the Projects or Work Breakdown Structure window
Change a layout's timescale format
Filtering data
Add line numbers
Define user preferences
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
