Merge or Delete WBS Element(s) dialog box
Use the Merge or Delete WBS Element(s) dialog box to confirm that you want to delete a WBS element. Also, if the WBS you are deleting has activities associated with it, choose one of the following options before clicking OK to confirm the delete action.
Delete Element(s): Deletes the selected WBS element and all activities assigned to it.
Merge Element(s): Deletes the selected WBS element and reassigns its activities to the WBS element.
Note
Related Topics
Parent Element
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
