Merge selected resource with its parent dialog box
Use the Merge selected resource with its parent dialog box to replace the deleted resource with another available resource. When resource security is enabled, you can only view resources you have access to.
Display Options bar: Click to change the resource display.
Resource ID: Lists the ID of each resource in your organization. To sort the display, click the Resource ID column label.
Resource Name: Lists the name of each resource in your organization. To sort the display, click the Resource Name column label.
Primary Role: Lists the primary role, if any, assigned to the resource.
Default Units/Time: Lists the default units/time for each resource in your organization. To sort the display, click the Default Units/Time column label.
Select: Replaces the deleted resource with your selection and closes this dialog box.
Related Topics
Introduction to Resource Security
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
