Use the Risks Details to view and edit detailed information about the selected risk. You can also use the Risks Details to define a risk's impact, to select a response, and to define new impacts based on the response. The Risks Details appear in the Risks view.
The available tabs are:
- General tab - Risks Details
- Impact tab - Risks Details
- Activities tab - Risks Details
- Description tab - Risks Details
- Cause tab - Risks Details
- Effect tab - Risks Details
- Notes tab - Risks Details
- UDFs tab - Risks Details
