Project Toolbar
Use the Project toolbar to access windows and dialog boxes in which you can view, add, edit, and delete project-level data, such as activities, the WBS, and resource assignments. This toolbar is displayed by default, and the icons are enabled when any project is open.
The following table provides information about each available icon on the toolbar.
Icon
Function
Displays by default?
Corresponding menu command
Opens the Activities window. Use the Activities window to create, view, and edit activities for the open project.
Yes
Project > Activities
Opens the Work Breakdown Structure window. Use the Work Breakdown Structure window to create, view, and edit the open project's work breakdown structure (WBS).
Yes
Project > WBS
Opens the Resource Assignments window. Use the Resource Assignments window to view all resource assignments, grouped by resource, for all currently opened projects. You can also display resource cost and quantity information in a spreadsheet.
Yes
Project > Resource Assignments
Opens the WPs & Docs window. Use the WPs & Docs window to create and maintain work product and document records for the open project, such as records for standards, procedures, guidelines, and templates.
Yes
Project > Work Products and Documents
Opens the Project Expenses window. Use the Project Expenses window to add, edit, and delete expense items for activities in the open project.
Yes
Project > Expenses
Opens the Project Thresholds window. Use the Project Thresholds window to create, view, edit, and monitor thresholds for the open project. You can monitor a threshold at the work breakdown structure (WBS) level or the activity level to identify issues.
No
Project > Thresholds
Opens the Project Issues window. Use the Project Issues window to add, edit, and delete issues for the open project and to send Email notifications about issues.
No
Project > Issues
This icon appears only when P6 Professional is connected to a P6 Professional database.
Opens the Risks view. Use the Risks view to add, edit, assign, and delete risks for the open project. You can also calculate a risk's exposure values and its overall impact on the project's schedule and costs.
No
Project > Risks
Opens the Assign Baselines dialog box. Use the Assign Baselines dialog to assign project, primary, secondary, and tertiary baselines to a project.
No
Project > Assign Baselines
Opens the Maintain Baselines dialog box. Use the Maintain Baselines dialog box to create, delete, copy, or restore baselines for the open project.
No
Project > Maintain Baselines
Opens the Set Default Project dialog box. When you open multiple projects, use this dialog box to specify which project to open by default, which project’s settings to use when you schedule or level, and which project to use by default when you add new information to the database.
No
Project > Set Default Project
Tips
Related Topics
Customizing toolbars
Activities
Expenses
Thresholds
Issues
Assign baselines to projects
Create a baseline
Modify a baseline manually
Copy a baseline
Update a baseline
Specify a default project
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
