Remove work product and document assignments from the Activities window
  1. Select the activity.
  2. Display Activity Details, then click the WPs & Docs tab.
  3. Select one or more work products or documents.
    To display the WPs & Docs tab, click the Layout Options bar and choose Bottom Layout Options. In the Available Tabs section, select WPs & Docs, click , then click OK.
  4. Click Remove, then click Yes.
Related Topics
Display window details
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
