Role codes
You can categorize roles using codes. With potentially hundreds of roles being used across an enterprise of projects, codes provide another method for filtering the roles you need to access quickly, or for grouping roles for analysis and summarization in layouts. You can also use role codes to group, sort, and filter roles in profiles and spreadsheets.
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
