Resource Codes or Role Codes dialog box
Use the Resource Codes dialog box to create, edit, and delete resource codes. Use the Role Codes dialog box to create, edit, and delete role codes. You can use these codes to sort, filter, group, and report on project data across the enterprise.
Select Resource Code: The name of the current resource code. You can select a different code.
Select Role Code: The name of the current role code. You can select a different code.
Modify: Allows you to create, modify, or delete codes.
Display Options Bar: Click to search for a specific code value and change the codes display.
Code Value: Lists code values for the current code. To change a value, double-click it. To sort the display, click the Resource Code Value or Role Code Value column label.
Code Description: Lists each code value's description.
Add: Adds a value to the current code.
Delete: Deletes the selected value from the current code.
Cut: Cuts the selected code value so you can delete it or move it to another position in the list. Select a new position, then click Paste.
Copy: Copies the selected code value so you can quickly create a similar value in another position in the list. Select a new position, then click Paste.
Paste: Pastes a code value you have copied or cut.
Arrows: Moves the selected value to a different position in the display. This changes the order in which the values display when you assign a value to an activity.
Note
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
