Select Currency dialog box
Use the Select Currency dialog box to select the currency in which you want to view all cost values.
Display Options bar: Click to change the currency display.
Search: Type a currency ID or currency name to display a filtered list of currencies whose ID or name begins with this value.
Currency ID: The ID for each available currency type.
Currency Name: The name of each available currency type.
Notes
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
