Select Resource dialog box
When P6 Professional is connected to a P6 EPPM database, use the Select Resource dialog box to assign a resource to an issue, to a user, or to a personal resource calendar. When P6 Professional is connected to a P6 Professional database, use the Select Resource dialog box to assign a resource to an issue, to a user, or to a personal resource calendar. Also use this dialog box to select the resource under which to place all resources from a Microsoft Project file during import.
If resource security is enabled, you can select resources only from under your resource root node or from current project resources.
Display Options bar: Lists options for changing resource columns, filters, grouping and sorting, font, and colors.
Note: When the Filter By, All Resources option is used, all resources display, even those assigned a personal resource calendar.
Select Resource table: Lists your organization's resource hierarchy. To sort the display, click a column label.
Select: Applies your selection and closes this dialog box.
Close:
When connected to a P6 EPPM database: Removes the selected resource from the current activity, issue, or user.
When connected to a P6 Professional database: Removes the selected resource from the current activity, issue, or user.
(This option does not display during the Microsoft Project import.)
Related Topics
Resource Security
Root Node
Current Project Resources
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
