Select WBS to Add into dialog box
Use the Select WBS to add into dialog to select the WBS node to which you want to add the new project.
Display Options bar: Click to change the WBS table display.
WBStable: Lists the ID, name, and additional information about existing WBS elements. To sort the display, click a column label.
Select: Adds the new project to the selected WBS element.
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
