Specify Gantt Chart bar data and display options
  1. Display the Gantt Chart, then choose View, Top Layout Options, Bars.
  2. To add a bar, click Add, mark the Display checkbox next to the new bar, and type a name for the new bar.
    To keep an existing bar, but exclude it from the layout, clear the Display checkbox next to it.
    To delete a bar, select it and click Delete.
  3. In the Timescale column, select the timeperiod you want the bar to represent.
  4. In the Filter column, select the filter you want the bar to represent.
  5. Click the Bar Style tab and configure the bar's style.
  6. Click the Bar Labels tab and specify the bar’s label.
  7. To preview the current bars without closing the Bars dialog box, click Apply.
  8. Click OK.
Related Topics
More Detail: Specifying a bar's timescale
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
