Top Layout Toolbar
Use the Top Layout toolbar to customize the top layout of the active window. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon
Function
Displays by default?
Enabled when active window is:
Corresponding menu command
Shows or hides the table view in the top layout.
Yes
Activities, Projects, Resources, WBS
View > Show on Top > Table
Shows or hides the Gantt chart in the top layout.
Yes
Activities, Projects, WBS
View > Show on Top > Gantt Chart
Shows or hides the Activity Network in the top layout. To set Activity Network options, open an Activity Network layout, or save the Activity Network layout, click the icon, then choose the appropriate option.
Yes
Activities
View > Show on Top > Activity Network
Shows or hides relationship lines in the Gantt Chart.
Yes
Activities
None
Shows or hides a chart view.
Yes
View > Show on Top > Chart View
Shows or hides the Activity Usage Spreadsheet in the top layout.
No
Activities
View > Show on Top > Activity Usage Spreadsheet
Shows or hides columns in the Project/Gantt Profile.
No
Tracking
None
Shows or hides the top window in the Project/Gantt Profile.
No
Tracking
None
Shows or hides the Resource Usage Spreadsheet in the top layout.
No
Resource Assignments
View > Show on Top > Resource Usage Spreadsheet
Arranges children horizontally or vertically in chart views. Click the icon to select an option.
No
View > Arrange Children
Aligns children in chart views. Click the icon to select an option.
No
WBS
View > Align Children
Enables you to apply an existing chart box template to the current layout, or customize your own. Click the icon to select an option.
No
View > Chart Box Template
Tips
Related Topics
Customizing toolbars
Activity Network
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
