View budget and spending plan totals
  1. Choose Enterprise, Projects, then select the EPS node/project for which you want to view budget information.
  2. Display Project Details, then click the Budget Summary tab to view calculated budget data from the Budget Log and Spending Plan tabs.
Related Topics
Display window details
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
