To set your compression settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Web Services/Compression.
Set the minimum size for response compression. responses smaller than this will not be compressed to gzip format.
Set a value between Between 0 and 2147483647 bytes, the default is 400.
