Configuring Registry Service in Services Settings
The registry service finds changes in the Primavera P6 Administrator configuration settings and deploys those changes in the server. If you are running services and P6 on the same server, you should keep the defaults. If you enter a longer rate, the server will run more efficiently, but the data may be out of date. If you enter a shorter time, the data will be up to date, but the server may not run as efficiently.
To set your registry service settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Services/Registry Service.
    1. In the Refresh Rate field, enter the rate when the Business Rule Engine status updates in the database.
      The default value is 1m30s.
      Enter a value between 15s and 1h.
    2. In the Stale Period field, enter the duration of inactivity that indicates an inoperable Business Rule Engine.
      The default value is 4m.
      Enter a value between 1m and 10m.
    3. In the Port field, enter the TCP/IP port that will receive requests to revive dead Business Rule Engines.
      The default value is 9192.
      Enter a value between 1 and 65535.
Related Topics
Configuring Infrastructure Services in Services Settings
Configuring Module Access Service in Services Settings
Configuring Timestamp Service in Services Settings
Configuring Mail Service in Services Settings
Configuring Next Key Service in Services Settings
Configuring Alert Notification Service in Services Settings
Configuring Collaboration Synchronization Service in Services Settings
Configuring Asynchronous Jobs in Services Settings
Configuring Project Hierarchy Cache in Services Settings
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
