Configuring Overallocation Check in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you want the server to check for overallocations immediately, you should set the Interval low (for example, 10s) and the Concurrent Threads high (for example, 20). Remember that if the server is actively checking for overallocations, all users will experience delays in the application.
Note: Enable the Project Arbiter service because projects will be published before running the overallocation service.
To set your overallocation check settings:
  1. Open the Primavera P6 Administrator.
  2. In the Configurations drop-down list, select your configuration.
  3. In the sidebar select Services/Job Services.
  4. Select Overallocation Check.
    1. In the Interval field, enter the amount of time to wait before running the next available job (in 1d1h1m1s format, specifying only numbers without letters implies milliseconds).
      The default value is 30s.
      Enter a value between 1s and 24d20h31m23s647.
    2. In the Concurrent Threads field, enter the number of processes used for this service on this server. A value of 0 indicates that that this job will not run on this server.
      The default value is 2.
      Enter a value between 0 and 20.
    3. In the Active Mode field, select true if you want jobs processed continuously until all jobs finish. Select false if you want each job processed according to the Interval.
Related Topics
Configuring Job Services in Services Settings
Configuring Scheduler in Services Settings
Configuring Leveler in Services Settings
Configuring Summarizer in Services Settings
Configuring Apply Actuals in Services Settings
Configuring Import/Export
Configuring Unifier in Services Settings
Configuring Global Replace Service in Services Settings
Configuring Sync Units
Configuring CopyProject in Services Settings
Configuring Baseline in Service Settings
Configuring GatewaySynchronization
Configuring Store Period Performance in Services Settings
Configuring Recalculate Assignment Cost in Services Settings
Configuring Rename Document Folder in Services Settings
Configuring CopyWBS in Services Settings
Configuring Export Excel in Services Settings
Configuring Import/Export Enterprise Data in Services Settings
Configuring Generate Reports in Services Settings
Configuring Checkin Enterprise Data in Services Settings
Configuring Checkout Enterprise Data in Services Settings
Configuring Printing in Services Settings
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
