To set your database instance settings:
- Open the Primavera P6 Administrator.
- In the Authentication tab, select your configuration from the drop-down list.
- Select your Database Instance.
- In the Authentication Mode drop-down list, select one of the following authentication modes:
Note: Changes to this setting require you to restart the P6 server.
- Native
- WebSSO
- LDAP
Note: Other authentication modes available in this list are used for P6 EPPM Cloud Service.
For more information about each authentication mode, refer to Authentication Modes in P6 EPPM.
