To configure the settings for P6 Team Member Web, you must have a P6 Team Member Admin Configuration. See Installing and Configuring P6 EPPM for more information on how to create this configuration during a new installation of P6 Team Member Web or P6 EPPM.
To configure the settings for P6 Team Member Web:
- Launch Primavera P6 Administrator.
- Navigate to your P6 Team Member configuration, and then expand it.
- Expand Application:
- Set the Help server URL to one of the following:
http://localhost:listenport/ContextRootwhere localhost is your server's host name, listenport is your P6 Team Member port number, and ContextRoot is the root for your Help.
- https://docs.oracle.com/cd/E90746_01/team_member/web/help/
Note: Oracle recommends that you use the second URL option because it ensures that you always access the latest version of the P6 Team Member Help, including critical corrections and enhancements.
- Expand Team Member:
- Expand Connection Pool if you want to alter the following default values:
- Initial connection pool size: 10
- Maximum active database connections: 150
- Maximum idle database connections: -0
- Minimum idle database connections: 10
- Expand Logging if you want to alter the following default values:
- Enable: enabled
- Severity Level: Error
- Log File Name: p6tmweb.log
Note: The primavera.bootstrap.home property determines the location of the log file.
