Authentication Configuration Process in P6 EPPM
By default, all P6 EPPM applications use Native authentication. After you install your P6 EPPM applications, you can choose a different authentication scheme.
Note: If you are upgrading from a previous version of P6 EPPM, see the P6 EPPM Upgrade and Configuration Guide before modifying the authentication settings.
Your database controls your Authentication mode.
Follow the guidelines below to specify an authentication scheme and perform additional configuration tasks for authentication:
Tips
Copyright © 1999, 2023
Last Published Thursday, January 12, 2023
