Note: Before you begin, ensure you are using the supported version of Safari. See the Tested Configurations document for more information.
- Open Safari.
- From the Settings drop-down, select Preferences.
- In the General dialog box, select Security.
- In the Web Content section:
- Select the following:
- Enable Plug-ins
- Enable Java
- Enable JavaScript
- Deselect Block pop-up windows.
- Select Advanced.
- Select Press Tab to highlight each item on a webpage.
- Close the dialog box.
Tip
Complete the following steps to enable the Java plug-in:
- In the Java section, select Run in Unsafe Mode for the P6 URL.
