To keep the Primavera Data Warehouse database current, run the STARETL process periodically. Typically, you will run the STARETL process nightly during off-hours.
You can use Task Scheduler (with Windows) or a cron job (with UNIX or Linux) to schedule STARETL process runs. Refer to your operating system documentation for specifics on how to configure the process to run as a recurring job.
You can also use the web-based Configuration Utility to schedule STARETL process runs. See the Primavera Data Warehouse Installation and Configuration Guide for details.
Caution: When scheduling STARETL process runs, Oracle recommends that you do not start a STARETL process run until the previous run has completed.
