You can manually include P6 EPPM projects to take advantage of the Work Planning tables and functionality.
You must create and configure the necessary P6 EPPM project-level user-defined fields (UDFs) that the STARETL process needs to include projects in Work Planning. To do this, complete the following steps:
- Sign in to P6 EPPM.
- From the Administration
menu, select Enterprise Data. - On the Enterprise Data page, expand Projects and select Project UDFs.
- On the Project UDFs page:
- Add a sys_workprocess UDF with a data type of Text.
- Add a sys_scope_freeze UDF with a data type of Text.
- Add a sys_schedule_freeze UDF with a data type of Text.
