Complete the following steps to verify the MapViewer connection:
- Access the MapViewer by going to the following URL:
http://<machine>.<domain>:9704/mapviewer
- Log in to MapViewer using the same administration user that you use to log in to the WebLogic and Enterprise Manager consoles.
- Select the Admin link.
- Select Data Sources.
You should see the data source that you just created. You should also see your machine.domain in your configuration if the changes were successfully committed.
