Setting Up R
After installing R, set up the R script to connect directly to STARUSER and calculates the predicted outcome for pre-selected projects as follows:
  1. Create table etl_aa, which contains the project_object_id for the projects that will be calculated.
    CREATE TABLE etl_aa(project_object_id number(19));
  2. Insert the project_object_id for the selected project.
    INSERT INTO etl_aa(project_object_id) values (4351);
    INSERT INTO etl_aa(project_object_id) values (4352);
    INSERT INTO etl_aa(project_object_id) values (4354);
    INSERT INTO etl_aa(project_object_id) values (3577);
    INSERT INTO etl_aa(project_object_id) values (4049);
    INSERT INTO etl_aa(project_object_id) values (4301);
    commit;
  3. Open R Studio.
    1. Install the following packages: rJava, RJDBC, glm2
      install.packages("rJava")
      install.packages("RJDBC")
      install.packages("glm2")
    2. Set the working directory to a folder that contains ojdbc6.jar.
  4. Open the attached R script.
    1. Change the database connection.
    2. Run the script.
      The results will be in W_UDF_PROJECT_D
Related Topics
Prerequisites for Advanced Analytics Example
Setting Up Oracle R Enterprise (ORE)
Copyright © 1999, 2020
Last Published Wednesday, October 20, 2021
