PAS Properties
Properties
Mandatory Data Type Format Size Default
Allowed Values
Usage detail
application.buildversion
NUMBER nn.nn.nn.nn 11
n - Digit from 0 to 9 inclusive
Defines the build version of the application on the login screen.
application.databaseType
YES Fixed List <=10
SqlServer
Oracle
DB2
The system-wide default database type. Used for multiple query support functionality and JDBC interaction.
application.default.buildversion
Only used if the property, application.buildversion,
is set and begins with '${' Defines the build version of the application on the login screen.
application.defaultCurrencyCode
YES Standard List
Value = https://www.currency-iso.org/en/home/tables.html
The default currency should be added as a CurrencyCode in the AsCurrency table.
application.defaultLocale
YES Standard List
As per IETF BCP 47, supported by JAVA
Specifies the language that the login screen will be displayed in.
Example: ja_JP: login screen will appear in Japanese.
Example: en-US: login screen will appear in English.
Note:Once the user logs in, the language is determined by that user's locale.
application.enablePlanGroup
Boolean 2 No
Value: No
If included, should be set to No.
application.enablePostAssignmentValidation
Boolean <=3 No
Value: Yes, No
Determines whether or not to execute the PostAssignmentValidateExpressions business rule during activity processing.
application.enableProduct
Boolean <=3 No
Value: Yes, No
Allows application to use the Products hierarchy in configuration.
application.mathApplicationCallbackBll
YES Alphabetic Fixed
Value: com.adminserver.pas.bll.PasCallBackBll
Internal PAS property. Class used to carry DataRetriever and RateRetriever to be used by the Math engine.
application.mode
YES Alphabetic Fixed List <=11
Value: DEVELOPMENT, PRODUCTION
Development mode is where configuration changes are allowed. Configuration data is not cached. Production mode is where configuration change is a new release and JVM is restarted when it is changed. Configuration data is cached.
Should be set to PRODUCTION in production environment.
application.refreshMasks
Integer +/-nnnnnn <=7
For use in application.mode = DEVELOPMENT Time in milliseconds to refresh mask configuration Value <= 0 will never refresh.
application.resourceCacheTimeout
Integer +/-nnnn <=5 -1
Time to cache translations, in minutes, before checking data source for updates. For value < 0, never check for updates. For value = 0, always check for updates. For value > 0, check for updates after specified minutes have passed. System Default is -1. Should be set to -1 in a Production environment.
application.theme
YES AlphaNumeric Fixed <=10
Value: Oracle
The theme used for page styles and images.
application.X-Frame-Options
AlphaNumeric Fixed List / Free text Parameter <=255 None
Value: DENY, SAMEORIGIN, ALLOW-FROM <url>
For support against CSRFattacks. Applies only to IE8 and above. If property is not specified, no system protection against CSRF is offered.
DENY => Any application page is not allowed to be framed.
SAMEORIGIN => Application is allowed to be framed in any page coming from the same root url. SAMEORIGIN means same root URL.
ALLOW-FROM <url> => Application is allowed to be framed from any page coming from the root URL specified in the property.
application.AccessControlAllowOrigin NO AlphaNumeric Fixed List / * <=255 None Value: <url>,*,
To enable the web server to make cross domain requests.
<url> => list of allowed domains, which are making service calls.
* => This allows access to all domains, but using this wildcard character is considered overly permissive policy.
database.nlscomp
Alphabetic Fixed List <=15 LINGUISTIC
Value: LINGUISTIC, BINARY, ANSI
Info:
Refer to https://docs.oracle.com for the version of Oracle used for a current listing of values you can specify for this parameter.
Only applicable if using the Oracle database. It provides the NLS_COMP setting that the system should use in the database session in order to perform Case/Accent insensitive search. Default value if not specified is LINGUISTIC.
Note:The DBA should setup appropriate indexes for this property and suggest the setting value to use based on the client installation's language preference.
database.nlssort
Alphabetic Fixed List <=25 BINARY_CI Info:
Refer to Database Globalization Support Guide and other related documents at https://docs.oracle.com/ for a current listing of values you can specify for this parameter
Only applicable if using the Oracle database. It provides the NLS_SORT setting that the system should use in the database session in order to perform Case/Accent insensitive search. The DBA should setup appropriate indexes for these properties and suggest the setting value to use based on the client installation's language preference.
Note:The default setting for OIPA is a sort that is accent-sensitive and case-insensitive.
datasource.type
YES Alphabetic Fixed 4 none
Value: jndi
The data source type.
jndi relies on jndi names ADMINSERVERDS, ADMINSERVERRESOURCEDS ADMINSERVERSEARCHDS and ADMINSERVERREADONLYDS in the application server for a datasource connection.
debug.identifyTranslator
Boolean <=3
Value: Yes, No
debug.remoteDebugging
Boolean <=3
Value: Yes, No
debug.SaveGeneratedClass
Boolean <=3 No
Value: Yes, No
debug.SaveGeneratedClassDirectory
AlphaNumeric File Path <=255
Directory where the generated source code should be saved.debug.SaveGeneratedClass needs to be set to Yes.
Warning: Only use in a Non-Production environment.
document.crystalConnectionCount
Whole Number nnnn <=4
Only valid for generating Crystal documents. Sets allowable connections. Should be set to a number not greater than the number of CR licenses.
document.documentGeneratorUrl
AlphaNumeric URL <=255
The url for the DocumentGenerator webservice url for generating documents.
document.documentPath
Directory where report templates are stored.
document.generatedDocumentRootPath
Directory where generated documents are saved.
extensions.config
Directory where extensions.xml for extension configuration is stored.
grid.taskSubmissionThreadPoolSize
Whole Number nnn <=3
The number of threads dedicated to submit tasks to the grid for processing. Increasing this number can speed up how quickly tasks are distributed to the grid. See cycle documentation for additional details.
jpa.databasePlatform
YES AlphaNumeric Fixed List <=100
Value:
org.eclipse.persistence.platform.database.SQLServerPlatform org.eclipse.persistence.platform.database.OraclePlatform org.eclipse.persistence.platform.database.DB2Platform
Property that determines which JPA DatabasePlatform to use with EclipseLink.
jpa.showSql
Boolean <=5 False
Value: True, False
Shows information in the application's log/console for all SQLs executed using JPA.
NamedStoredProceduresRateBll.config.filePath
AlphaNumeric File path <=255
Configuration file path used by default RateRetriever implementation com.adminserver.bll.NamedStoredProceduresRateBllclass.
XML file that specifies the stored procedure to be execute for specific rate groups. If using this, leave rateRetriever.className blank.
AlphaNumeric Java Class FQN <=255
Fully qualified extension class name to retrieve rates for all rate groups.
Warning: If using this, leave NamedStoredProceduresRateBll.config.filePath blank.
requirement.service
Boolean <=3
Value: Yes, No
requirement.service.period
Unsigned Integer nnnnnn <=6 60000
If the background requirement processing is on the value, this setting specifies the period of time between checks performed by the background requirement processor to see if there are any requirements ready to be processed - in milliseconds.
requirement.service.logErrors
Boolean <=3
Value: Yes, No
scheduledValuation.batchSize
This is the batch size for processing scheduled valuation. See cycle documentation for additional details.
scheduledValuation.period
Unsigned Integer nnnnn <=5
This is the number of seconds that the scheduled valuation monitor task will sleep before waking up and checking on the status of queued tasks. See cycle documentation for additional details.
scheduledValuation.groupSize
Unsigned Integer nnnnnnnn <=8
Determines the number of Scheduled valuation items to group together and execute on a single thread in the cluster.
search.field.text.caseInsensitive
Boolean <=5 False
Value: True, False
Search screens have the ability to perform their search in a case insensitive manner. A value of True makes the system use case insensitive searches.
Warning: For use when the system is running on the DB2 database platform only!.
transaction.manager
YES Alphabetic Fixed 3
Value: jpa
Data source transaction manager.
webservice.allowHashedPassword
Boolean <=3
Value: Yes, No
Determines if web services can be invoked with hashed passwords. If not specified, system sets default value as No. Valid values are Yes,No.
WriteValuationXML
Boolean <=3
Value: Yes, No
Boolean <=3
Value: Yes, No
application.configurationCacheTimeout
Positive Integer nnnnn <=5
For value = 0, never check for updates.
document.uploadDirectory
Directory where uploaded documents are saved.
application.encryptDecryptFilePath
YES AlphaNumeric File Path <=255
Value of this property should be absolute path with file name, where EDKeyValue.dat exists. This .dat file holds the partial Encrypt/Decrypt Key for encryption/decryption of the data. This file comes as part of distribution zip.
jpa.targetServer
YES AlphaNumeric Fixed List <=15
Value: none,Websphere_7,WebLogic_10
Determines the target server for this installation
dataIntake.userName
AlphaNumeric
Value: Text
Name of a user (client number) that will be used during data intake processing. Should have a matching user in the database
async.AsFileTaskExecutor.corePoolSize
YES Positive Integer nnn <=3
AsFile Asynchronous Task Executor ThreadPool Properties
async.AsFileTaskExecutor.maxPoolSize
async.AsFileTaskExecutor.queueCapacity
YES Positive Integer nnnnnn <=6
session.timeout Positive Integer Value : Integer (Value representing minutes)
Timeout interval for the session to expire. This is in minutes and defines the idle period after which session has to expire.
If this is not configured , default value is 30 minutes
session.graceperiod   Positive Integer       Value : Integer (Value representing minutes)
Grace period is the time period just before the actual timeout , when timeout warning popup is displayed.
If this is not configured default value is 1/10 th of session.timeout
updateActivityEntryDateOnEdit.enable   Boolean     No Value: Yes, No
Used to show the 'last modified date/time' for pending activities.
If the value is set to Yes the last modified date/time will be shown when hover over on a pending activity.
If set to No the last modified date/time will not be shown. The default value is No
workflow.enabled   Boolean     No Value: Yes, No
Used to derive the workflow feature.
If the value is set to Yes, this feature will be enabled.
application.systemAudit   Boolean     No Value: Yes, No
This property is used to enable audit trail.
Set to Yes to record audit trail for changing the input data when business error occurs on activity.
The default value is No.
spawnPartitionSize   Positive Integer nnn     Value : Integer This is the size of partition list when there is more or equal to 1000 parameters in the list.
HideNonInvestFundValuation   Boolean     Yes Value: Yes, No
This property is used to enable HideNonInvestFundValuation.
Set to yes to Hide Non Invest Fund Valuation.
The default is Yes.
multipleLoginAllowed   Boolean     Yes Value: Yes, No If the value of this property is set to 'No' then user will not be allowed to login to the application using same user id with either two different machines or two different browser. If the value is set to 'Yes' then user will be allowed for multiple logins to the application.
rateCriteriaConfiguration.enabled
  Boolean     No Value: Yes, No Rate Criteria Columns Configuration
environment.name   AlphaNumeric         Environment name
partitionSize   Positive Integer nnn     Value : Integer This is the size of partition list when there is more or equal to 1000 parameters in the list.
application.enableAccessLogs   Boolean     No Value: Yes, No This property is used to enable AccessLogs. Set to Yes to Enable Access Logs.
activityDetail.columnView   Boolean     No Value: Yes, No
This property is used to enable activity detail column view. If Detail text is too long it will truncate that text and shows full text in tool tip.
Set to Yes to enable activity detail column view.
application.enableAccessToken   Boolean     Yes Value: Yes, No This Property is used to enable or disable access token. This Property will accept 'Yes' or 'No'.
authorization.disablePlanPageAndButtonSecurityOverride   Boolean     No Value: Yes, No
This property is used to disable authorization of AuthPlanPage and AuthButton in case of large number of group plans. The property value is set to 'Yes' to fetch all the data from the product level.
requirement.service.corePoolSize Yes Positive     50   Above property is to set thread pool size for Requirement task execution. Need to set it based on the availability of hardware – Required Setting
requirement.service.initial.delay No Positive     180000   Above property is introduced to set some initial delay for scheduler to start and pick tasks for processing. This is to reduce load on other processes during server start up (E.g.: Coherence cache initialization). With this setting, requirement processing will wait for above configured time in milliseconds to kick start. (180000 - 3 minutes) – Recommended setting Default will be 0.
requirement.service.exclude.status No AlphaNumeric     05, 11   Currently requirements of all the statuses are picked up by Processing Engine by default which includes (Completed – 11, Canceled – 05 etc.). Above setting helps the processing engine to exclude few requirement statuses for processing. – This is an optional setting based on business requirement. But if we clearly know the statuses like completed and canceled are not to be picked again and again by processing engine, please use the above setting. Status codes to be given in comma separated values as mentioned below. Default – No requirement status is excluded.
